Digital I/O
Use PCI cards in PXI chassis and c++
HI,
I am currently using 2 PCI 6733 on an old experimental setup and I'm controlling the analog outputs of these cards using a c++ code.
I want to upgrade the setup. Nowadays computers do not have many PCI slots so I'm thinking about using a PXI chassis (that we already have) to put the PCI 6733 inside. I saw that PXI is similar to CompactPCI, but most of the adapters use 1 CompactPCI slot for at least 2 PCI.
Will I still be able, with a c++ code, to independently control each output of each card if I do this ?
Other question,
have you some splitted cables to connect one PCIe-6738 to two BNC2110?
Thank you in advance,
Sincerely
(2,290 Views)
I am on a similar position at my job, we are thinking on using a PCIe/PXIe adapter but we are unsure that it might raise bios compatibility issues or driver compatibility issues. Have you handle it somehow?
(2,055 Views)
I tried but we had some issues with our PXI chassis. So We bought this:
https://www.amazon.fr/Startech-adaptateur-connecteur-imprimante-parall%C3%A8le/dp/B000UZL1GC/ref=sr_...
And with Windows I manage to control 2 PCI 6733 independently with my C++ code. I did not try with linux yet.
Sincerely
(1,869 Views)
