Digital I/O
Using 6534 for repeated pattern
I am trying to use a PXI-6534 to output a 16-bit repeated pattern initiated by an external trigger.
My environment is:
Win 2000 SP4
Visual C++ 2005 (V8)
NIDAQ Legacy V7.4.2
I can successfully operate the 6534 by reloading the pattern buffer each time, using the same code that worked for the 6533. However, when I modify the code to preload the pattern, the pattern is never output. Since there does not seem to be any example code that addresses this application, I am posting this message.
The code that works is similar to this (less error detection):
Init_DA_Brds(mwPatternDevice, &wBoardCode);
DIG_Grp_Config(mwPatternDevice, mkwPatternGroup, 2, 0, 1);
Set_DAQ_Device_Info(wPatternDevice, ND_DATA_XFER_MODE_DIO_GR1, ND_UP_TO_1_DMA_CHANNEL);  Set_DAQ_Device_Info(wPatternDevice, ND_DATA_XFER_MODE_DIO_GR2, ND_UP_TO_1_DMA_CHANNEL);
DIG_Block_PG_Config(mwPatternDevice, mkwPatternGroup, 1, 0, mwStimBase, mwStimCtr, 1);
DIG_Trigger_Config(mwPatternDevice, mkwPatternGroup, 1, 0, 0, 0, 0, 0, 0);
loop:
DIG_Block_Out(mwPatternDevice, mkwPatternGroup, mpwPattern, mwPoints);
do { // while jRemaining
    <wait for external trigger via other hardware>
    DIG_Block_Check(mwPatternDevice, mkwPatternGroup, &jRemaining);  if (iStatus != noTransferInProgError)     NIDAQYield(1);
    } while (jRemaining && mbRunning);
goto loop;
The code as modified for the 6534 looks like this:
loop:
goto loop;
Note that I removed the transfer mode calls and moved the block_out call to outside the loop. The loop runs, but the pattern is not actually output from the board.
(3,276 Views)
Hi Charles Hamm,
In order to repeatedly generate the same block of data, you must set ND_PATTERN_GENERATION_LOOP_ENABLE in the Set_DAQ_Device_Info function to ND_ON. There are a couple restrictions when looping from the onboard memory. If you are using 8-bit data, the buffer size must be a multiple of 4. If you are using 16-bit data, the buffer size must be an even number. There are no restrictions for 32-bit data.
This information can be found in the NI 653x User Manual for Traditional NI-DAQ at the top of page 2-12.
Please post if you have any questions. Have a great day!
Ryan D.
District Sales Manager for Boston & Northern New England
(3,245 Views)
