Digital I/O
Using FPGA Targets in a LabVIEW Project (FPGA Module)
Hi, I'm trying to add an FPGA Target in the Local Development Computer according http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgahelp/adding_an_fpga_target/
Here are the steps :
  1. Create a new project or open an existing project.
  2. Right-click My Computer in the Project Explorer window and select New»Targets and Devices from the
But I do not find Targets and Devices in the menu New. I have only this window (see attached file).
Is there something to do before ? I have installed the FPGA module.
Thanks for your response.
(6,056 Views)
Ok, I have the menu right now after installing RIO driver.
The problem is that the FPGA Target contains nothing to select. In fact, I have no physical card installed in the PC. I would like to simulate a FPGA.
See the attached file.
Thanks.
(6,049 Views)
Many people here (including myself) do not open Word documents that are posted.  To many chances of viruses.  If you have a screenshot, post the actual image file (jpeg or png are perfered, bmp are disallowed).
Now, assuming you have the LabVIEW FPGA Toolkit installed, there should be an option to create a virtual device when creating a new FPGA target.
(6,043 Views)
Accepted by topic author sfla
Ok, but it is not necessary, I have found myself. Thanks.
(6,038 Views)
