Digital I/O
Using LabVIEW to switch from logic low to logic high on USB 6008
I am quite new to labview and I am having trouble programming my USB 6008 for digital triggering of my stepper driver. I need to be able to push a button that ouputs a continuous logic low voltage from a digital output and switching that button it changes to logic high. Can this be done easily? Also I need to just simply turn on and off a digital output of 5v using a push button. Any help with this would be greatly appreciated. I am running labview version 8.5.1
Thank you
(3,313 Views)
Very simple. The shipping example called Write Dig Chan will work. Both of your buttons do the same thing and would be part of a Boolean Array on the front panel. A simple mod would be to use separate buttons on the front panel and a Build Array on the block diagram. Numerous other ways. A single DAQ Assistant or one for each button could also be used.
(3,296 Views)
