Digital I/O
Using NI6587 in high speed mode 1GS/S in parallel mode
Hi
We use the NI6587 + PXI-7952R
I am looking for examples of program of using this configuration in high speep Mode (1Gs/s). I want to acquire a bus of 8 bits from a ADC device.
Thanks for your help in advance,
Sebastien
(5,386 Views)
Papa,
There is a good instruction set on getting everything up and running. Not always the easiest to find if you don't know what you are looking for though.
Start with the FGPA Module Installation Guide. This walks you through the hardware install, making sure the FGPA module is installed and so on.
Make sure you have the NI FlexRIO Adapter Module Support installed. This gives you examples to work from. That link is for version 3.4 (I believe the latest).
From there, reference the NI 6587R User Guide and Specifications. It has a good walk through of creating an FPGA project and working with the device.
Hope this helps!
Aaron W.
CLA, CTA and CPI
(5,379 Views)
