Digital I/O
Using USB-6525 solid-state relay module to control 25VDC solenoid valves, are flyback diodes necessary?
We will be using USB-6525 to drive solenoid valves.  The solenoid valves operate at 24VDC at 300 milliAmps.
Do I need to add flyback diodes between the solenoid valves and the USB-6525 to protect against flyback currents?
thank you,
Buddy Ehrlich
sehrlich@cytonomest.com
(4,340 Views)
Yes, and actually the diodes are in parallel with the valves. 1N400x series are typically used.
Refer to pages 11 and 12 of the manual:
http://www.ni.com/pdf/manuals/371818b.pdf
-AK2DM
(4,334 Views)
