Digital I/O
Using USB 8451 for nine SPI slave devices
I have 9 SPI slave devices and one USB 8451. If I use an extra Digital output (from another PXI 6515 which is having spare DO channels) as Chip select for the ninth slave , can I use the 8451 as its master?
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(4,231 Views)
Using the technique described here I theorise you could set ALL the onboard CS lines high, then use your external digital output set to a low to select the chip connected to it, then send your data.
Please let me know if you make progress with this!
(4,224 Views)
Thank you very much, Mark.
Since I don't have the hardware right now, can't validate it.
Will update you once I get hold of the hardware.
(4,201 Views)
