Digital I/O
Using low-level Digital i/o functions with the AT-DIO-32HS
I just want to confirm I can use lower-level DIGITAL I/O functions with the AT-DIO-32HS card. I needed to use the functions: DIG_In_Line(), DIG_In_Prt(), DIG_Out_Line(), DIG_Out_Port(), ...  These functions, according to the TRADITIONAL NI-DAQ manual, appear they can be used with the AT-DIO-32HS.
Thank You !!
Message Edited by Raminta on 12-11-2006 10:51 AM
(3,170 Views)
Hi Raminta,
Yes, you can use those functions and almost any of the Traditional DAQ manual.
Remember the device is plug and play, look at this forum if you have questions how to install it.
When you search the DAQ manual, remember that in the conventions section you have the following statement:
653X device Refers to the AT-DIO-32HS, PCI-DIO-32HS, DAQCard-6533, PXI-6533, PCI-6534, and PXI-6534.
Meaning that your device is "referred" as 653x.
Good luck!
Gerardo O.
RF SW Engineering R&D
(3,151 Views)
