Digital I/O
VXI DIO-128, LabView 2012, Win 7, Traditional DAQ 6.9.3
I would just like to get confirmation that I have done my research.  I need to control my NI VXI DIO-128 card.  It does not look like my current configuration has any chance to work.
I have an existing test system that is being upgraded.  The system uses the NI VXI DIO-128.  The computer is upgraded to run Windows 7 and LabView 2012.  The VXI chassis controller is the VXI-USB.  I currently have Traditional DAQ 7.4.4 and DAQmx 9.6 loaded.  Based on my research, it appears that the last version of DAQ drivers that support the DIO-128 is 6.9.3 and I don't think these drivers are compatible with Win 7.  Is this thinking correct?
Thanks for your excellent support.
(5,553 Views)
That's correct. You would need a different os. I don't know if even xp supports something that old.
(5,546 Views)
