Digital I/O
Wait after Digital Trigger
I am running a VI which triggers analogue input from an accelerometer on the first digital edge from a light sensor pulse, measured against the internal clock on the cDAQ chassis. However, the light gate occasionally re-triggers shortly after the first falling edge due to the rebounding of the probe that initially triggers it. I would like to re-configure the VI to prevent triggering after the first event, either for a configurable time span or until the user resets it via a control.
I have previously overcome this problem by comparing the calculated speed that the probe has passed through the light gate (by using the period of the pulse and the width of the teeth of the probe...) to a minimum speed, and discarding anything that is acquired from a trigger corresponding to that lower speed, but recently test conditions have resulted in rebound speeds that are comparable in size to the downwards speeds, so this is no longer useful.
Please find the relevant section of VI attached - I couldn't include the entire VI because it's huge! Instead I've just removed the section that acquires the digital pulses and the analogue input. Any thoughts or opinions are welcome.
I am using the following hardware - 9401 digital I/O module and 9233 IEPE analogue input module, both mounted on cDAQ 9172 chassis, with the 9401 in one of the PFI slots - and running LabVIEW 8.0 / 8.20, NI DAQ 8.0.
CLA
(3,232 Views)
Hi there,
I'm not sure exactly what you're trying to achieve.  Are you saying you want to ignore the first falling edge after the start trigger? It sounds like you were doing that before, when you said you were discarding certain samples.  Depending on the speed you're trying to achieve, you could just put a software delay (eg. Wait function) in between each re-triggering iteration (between the stop of one iteration and the start of the next), so that you don't acquire anything (or receive triggers) in between.
Way S.
NI UK Applications Engineer
Message Edited by TheWay on 08-08-2007 07:31 AM
(3,224 Views)
