Digital I/O
What are the min and max output voltages and currents for PXI-6512 cards?
I want to know the followings about PXI-6512 digital output cards?
        - Minimum output voltage
        - Minimum output current
        - Maximum output voltage
        - Maximum output current
(3,705 Views)
see here
(3,702 Views)
Hello KizKas,
Thank you for posting to the NI Forums! The best way to find a particular specification for a product is to go to ni.com and search for that product's model number (i.e. 6511). By clicking on the link for your particular product, you will be directed to the product page. There you will see a tab called Specifications. You can click on Detailed Specifications under this tab and access the specs of the device. Also, you can click on the Resource Tab and access all manauls associated with the device. Have a great day!
Margaret Barrett
Digital Multimeters and LCR Meters
(3,675 Views)
