Digital I/O
What is the max Current on the Digital Output of a BNC-2110 Terminal
Im an using a 6221 DAQ card with a BNC-2110 Terminal Block connected to it. For the digital I/O block to the terminal provides an extra 5V input. Unfortunately I don't seem to find any information as to whether this provides extra drive current to the TTL signal or not. Is there an internal driver in the terminal block, or - if i need to connect external relays to the digital output - do i still connect a current driver in between?
Wolfgang
(3,765 Views)
Accepted by topic author WDinPA
You might want to re-read the 6221 and BN_2110 manuals. The +5V pins are outputs of the DAQ board - they are not inputs.
Yes, you will need external circuitry if the external relays require more current than what the DAQ card can provide.
(3,757 Views)
Thanks for the quick response. I indeed did not catch it that it is an output, not a 5 Volt input.
No problem, i will add a signal driver - was just hoping to be able to take a shortcut.
Thanks again,
Wolfgang
(3,753 Views)
