Digital I/O
When config DIO port (PCI-6052E) as outputs the DIO%233 stay only in red state (in test panel), I can't controled it
Hi PetyoSp,
could you please specify your problema bit more precise? What do you mean with "DIO%233"?
Jano
(4,684 Views)
I meant that the line 3 of DIO can't be managed. When configured as outputs or Input Line State is always RED independently of Logical Level,It isn't managed. All other Line managed correctly
(4,681 Views)
could you please attach your system information from MAX( Measurement and Automation Explorer) ?
I'll try to install the same version of software and we will try to troubleshoot the issue further.
Jano
(4,675 Views)
Hi
Thanks for your reply, I send you two files
Petyo Spasov
(4,663 Views)
so MAX in version 2.2.0, let's see 🙂 I'll have to try it out at the office, I'll get back to you once I have it set-up.
Jano
(4,652 Views)
