Digital I/O
Where do I find the maximum bit rate for the cable SHC68-C68-RDIO2
Search on web site unsuccessful - maximum measured performance is an important specification!
Message 1 of 9
(5,207 Views)
that cable can perform the speed of each card where it is listed as accessorie.
If that did'nt helped, than please tell me Your hw-setup and what type of signals You are aquiring.
Regards
Pascal
Message 2 of 9
(5,179 Views)
I am planning to use the PXIe 7821 where the theoretical maximum using 16 DIO's at 80 MHZ is 2x80MHzx16=2.560Gb/s (assuming double data rate)
I am concerned only that in the specifications that it is not explicitly stated that the cable can support such data rates.
I would also welcome a real world test to list the practical maximum data rate that one could achieve.
Message 3 of 9
(5,177 Views)
.... the application is the SPI transmission of data to the FPGA
Message 4 of 9
(5,176 Views)
thank you for the information. The data rate of the cable is not lower than the maximal datarate from the card.
If a high datarate is needed to be transferred to another PXIe card, it is important to select a PXIe Chassis with a high datarate. They can be found using the PXI Advisor on www.ni.com/advisor
Lucia
Message 5 of 9
(5,147 Views)
Thanks for the reply.
I am planning to use the PXIe 1082 chassis - system bandwidth up to 8GB/s according to specifications
Message 6 of 9
(5,142 Views)
so it depends on the datarate you want to transfer via the backplane of the pxi chassis, if this bandwith is enough for you.
How many values do you want to transfer to other PXIe cards or to the controller?
Lucia
Message 7 of 9
(5,136 Views)
I would like to connect 6 RDIO2 cables to 2 PXIe 7821 FPGA cards (ie) 3 cables to each card so 7.68 Gb/s to each card )
One question  is does this chassis support the maximum data rate to transfer the data to memory
The other question is what is the data rate limit for a peer to peer transfer to another 2 cards in the chassis - and I must be careful about exactly which slots I use?
Thanks for such detailed questions this helps a lot with the planning
Message 8 of 9
(5,133 Views)
Accepted by topic author momolxg
in this case we should look at the overall system. The chassis 1082 is quite big for 2 cards. Which other cards are planned in the system?
The PXIe 7021R has in the datasheet a limit on the data transfer rate to the PXIe Backplane of the chassis, which is 500 MB/s.
I would prefer to advise you in this case through the Technical Sales Service. You can reach me by phone or mail:lucia.nagl@ni.com.
Then we can discuss the entire project.
Lucia
Message 9 of 9
(5,117 Views)
