Digital I/O
Which NI-DAQ [6.1, 6.8.1, 6.9.3, 7.0] support VC++ DIG_ functs on the NI 6503?
Need to upgrade an old ISA PC that has a PC-DIO-24 and runs a Visual C++ 6.0 app which uses the NI-DAQ 6.1 functions DIG_Prt_Config(), DIG_In_Prt() and DIG_Out_Prt().  The new PC has only PCI slots.  Want to use the PCI-6503, which is pin-compatible, but am not sure which "Traditional" NI-DAQ software versions [6.1, 6.8.1, 6.9.3, 7.0] support it.  Would like to reuse existing application software, if possible.  Could not figure out where to find this info on NI's web site.
(3,253 Views)
Hello dmedendorp,
It looks like you want to use the PCI-6503 with Traditional DAQ driver with Visual C++ 6.0.The latest driver for Traditional DAQ is 7.4.1. This driver is compatible with this hardware. In the future you can reference this site for information about DAQ driver Support for Hardware devices.
Data Acquisition (DAQ) Installation/Configuration Troubleshooter NI-DAQ Driver Support
Happy Coding!
  Sandra T.
Applications Engineer | National Instruments
(3,242 Views)
