Digital I/O
Why is my PXI-6534 causing PC hangup problems?
I'm developing a dll in LabWindows CVI for automatic testing with TestStand.
My application is pretty simple. I configured group 2 (w/ port 2 and 3) as input and I'm using port 0 as output. I need to aquire a fixed amount of data when I detect a hardware stop trigger. For setting up the stop trigger, I'm calling DIG_Block_PG_Config, DIG_Trigger_Config and DIG_Block_In functions. To see if the data transfer is completed, I'm using DIG_Block_Check function. Everything is working fine but the problem is only when the rate is 10MHz and the number of data points is < 100. In this case, I see that the Rx & Tx LEDs on the DAQ card are ON all the time and my system just hangs up. What can be the possible reasons for this?
I'm attaching my program.
(3,197 Views)
Do you get the problem while trying any examples from c:\program files\national instruments\ni-daq\examples\visualc\di ?
Please do let me know the example. I would definitely try to reproduce it.
Sincerely,
Sastry
(3,197 Views)
