Digital I/O
Will an NI-9481 Relay module work in a USB-9162 carrier?
I want to use an NI-9481 C Series relay module in a single slot C Series carrier (not the 8 slot CompactDAQ chassis).  If you purchase a USB-9233 you get a NI-9233 C Series module AND a USB-9162 single module C Series USB carrier.  I want to know if the NI-9481 C Series relay module will work when installed in the USB-9162 carrier.  By work,  I mean will I be able to program it using NI-DAQmx.
Jeff
(4,274 Views)
Yes, the 9481 module is supported by the USB-9162 carrier in NI DAQmx.  You can see a list of supported modules at ni.com/info code: rdcdaq.  The column of interest is "NI USB (NI DAQmx)" which uses the 9162.
(4,269 Views)
Great.
Thanks Chris.
BTW: Do you know if you can acutally purchase a USB-9162 carrier?  It doesn't show up on the website, but I haven't tried phone support yet.
Jeff
(4,262 Views)
The USB-9162 is offered as part of the USB-9233, USB-9481, USB-9215, etc. and is not available by itself.  Are you looking to take a module originally purchased for cDAQ or cRIO and now use it by itself over USB?
(4,257 Views)
Hmmm...
Well that appears obvious.  For whatever reason, I couldn't find the USB-9481 on the NI site before.  No, all I want is a 9481 module in a single USB carrier.  The USB-9481 will work just fine.
Thanks again.
Jeff
(4,252 Views)
