Digital I/O
Will this configuration work, what cables am I missing?
I'm working on a DIO system, and want to make sure I got all the parts down right.  Coming from the computer out to the IO modules, I have:
USB-6509
R1005050 Cable (0.5m)
2x SC2054
4x (No idea what cable)
4x SSR24 Backplane
35x 70M-ODC5 DC Output
45x 70M-IDC5 DC Input
Will this system work as described?  Also, what cable do I need between the SC2054 and the SSR?  Thanks in advance.
(3,916 Views)
Hi DamFrash,
I've been looking through the specs pages of the different devices and cables.  It looks like you have everything you need to connect.  The SC2054 appears to be able to connect directly to the SSR.  The data sheet lists SSR as one of the "works with" categories, and it does not say anything about needing another cable.  However, I would recommend contacting 1-866-ASK-MYNI, to get in touch with a customer service representative to see if you have all of the necessary components for your application.
(3,895 Views)
