Digital I/O
Windows XP compatible with AT-AO-6/10 ??
Hello
I have recently upgraded to windows XP from win95...As soon as I plugged the previously fine working AT-AO-6/10 board ( ISA bus) I was not even able to "see" the board through the MAX application. I am using Legacy 7.2 after an advice of the local french tecical support. So is this normal ?? In some web pages on ni.com I show that Legacy donnot support these boards under XP. Still the Tech Support insisted it is possible. I use Labview 7.1. Any help really appreciated. Regards George
(3,314 Views)
Hi George-
The AT-AO-6/10 is not supported under Windows XP.  The most recent operating system to be supported is Windows 2000 using Traditional NI-DAQ (Legacy) version 7.4.1.
Hopefully this helps-
Tom W
(3,305 Views)
