Digital I/O
Wire mapping for SHC68-68 cable, as I need to modify, please.
I would like to modify a SHC68-68 cable by removing the destination connector and fitting one of my own.  Please supply the wire mapping information (including the wire colours), so that I can create the wiring schedule.
Jon H
(4,363 Views)
Ummmm.   Perhaps you could determine that by empirical means.. to wit.
Tools and materials
1 DMM
1 Wire stripper
1 Knife
1 Cable cutter
Optional- 1 SCB-68 breakout board
A) take existing cable and cut it 6-10 cm from the end you want to replace
B) remove 4-6cm of outer insulation from portion to discard
C) remove  1/2 -1cm of insulation from each conductor.
D) use an ohm-meter to test connectivity from each pin to its associated wire.
Smiley Wink
(4,351 Views)
Of course, the easier way is to use the SCB-68 and wire its outputs directly to your new connector.  Smiley Happy
(4,348 Views)
Thanks for both of those suggestions.  Unfortunately, the SCB-68 breakout board is too large for my application and I was trying to avoid having to buzz out the cable.  I was hoping that NI would have a published wire mapping, as they seem to have for most of their other cables.
Jon H
(4,323 Views)
Hey Jon,
Here's an early holiday present:
I'll try to have someone post this online after the first of the year, but this should get you started.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(4,316 Views)
Brilliant!  Thanks Seth.
Happy New Year,
Jon H
(4,242 Views)
