Digital I/O
Wired-Or Outputs in Burst Mode
I am trying to configure a port for Burst mode with the lines in Wired-OR configuration in LabView version 7.1. I tried using the Port Config VI but it returns an error because the channel is already assigned.
(3,663 Views)
Greetings,
Check out the following KB for a little more info:
http://digital.ni.com/public.nsf/websearch/10056451DBB55A3A86256C61007117B1?OpenDocument
Which error number are you getting?
AnujD.
(3,663 Views)
Greetings,
Additionally, it is important to mention that One more thing Wired OR can only be used for static operations. Pattern I/O, burst, or handshaking will not allow it. This could be another reason why you are receiving this error.
AnujD.
(3,663 Views)
Thank you for your help. I solved my problem by adding a tri-state buffer chip to the SCB-68 breakput box I'm using.
(3,663 Views)
