Digital I/O
Would PCI-6527 be able to direct replace by PCI-6515
Hi could any one help me with this.  I have an application running on version 7.3 using NI-PCI 6527. This version  is obsolete and recommended replacement to PCI-6515 .  I have been asking this question to the Singapore support for the last 2 years and the answer is " I will get the Engineer to reply you."
My Question is.  I have an application running on Software version 7.30 using PCI-6527.  Is PCI- 6515 a direct replacement,?  mean I do not have to get the application upgraded or rewrite.  My application is simple and use only Input port"0" bit 0 - 7 and output Port 3 bit 0-7. rarely but possible  port 4 bit 0-7 and port 5 bit 0-7.
port 0-2 are input and 3-5 are output port.
Message 1 of 1
(4,163 Views)
