Digital I/O
Write to single line with DAQmx
life was so easy with traditional DAQ...
I'm trying to control single lines of DIO cards with DAQmx und CVI 8.0.1 , - the equivalent in traditional DAQ would be "DIG_Out_Line"
What I do:
- I create a task
- I add one channel for each digital line
DAQmxCreateTask (tsk_MAIN_OUTPUT_A, &tMainOutputA);
DAQmxCreateDOChan (tMainOutputA, "Dev1/port0/line0", "Line0",DAQmx_Val_ChanPerLine);
DAQmxCreateDOChan (tMainOutputA, "Dev1/port0/line7", "Line7",DAQmx_Val_ChanPerLine);
When I look into the "WriteFunction" collection, I find all kind of functions that write to tasks, but none which writes to channels...
The examples which comes with CVI only writes to a port, - 8 bit at a time, - which is what I want to avoid...
What am I missing?
Thanks a lot!
Greg
(5,356 Views)
Hello Greg,
You can control each of the individual lines of a DIO card by using a separate task for each line.  A DAQmx task is a collection of virtual channels, timing and triggering information, and other properties regarding the acquisition or generation. If you want to have the ability to write to a single line you'll want to have each of the lines in separate tasks.  Otherwise, you can include all of the lines in a single task and write to them all at once.
You may find these links helpful since you are just getting started with NI-DAQmx:
Transition from Traditional NI-DAQ to NI-DAQmx
Learn 10 Functions in NI-DAQmx and Solve 80% of Data Acquisition Applications
Post again if you have any further questions,
Micaela N
(5,340 Views)
Hello Micaela,
I've found out about the difference of tasks and channels in the meantime. However, thanks a lot for answering. The application is running fine now.
Best Regards,
Greg
(5,334 Views)
I have a 6516 card and I'm try to control the eight lines on port 3 individually.  I've gone through all the sample code and such.  Is this card capable of this?  Here's the code that I have write now.
Dim digitalWriteTask As Task = New Task()
digitalWriteTask.DOChannels.CreateChannel("Dev1/port3/line0", "port1", ChannelLineGrouping.OneChannelForAllLines)
Dim writer As DigitalSingleChannelWriter = New DigitalSingleChannelWriter(digitalWriteTask.Stream)
writer.WriteSingleSamplePort(True, 1)
I've tried ChannelLineGrouping.OneChannelForEachLine and DigitalMultiChannelWriter with no luck.  I also tried making a task in MAX to control Dev1/port3/line0 and this doesn't work either.  I'm starting to think this isn't supported on this card.
Could any shed some light on this for me.
Thanks in advance,
Gary
(4,955 Views)
Doh!  Sorry about that.  I had forgotten to wire the last port.  It works fine now.  It's definitely Monday.
(4,950 Views)
