Digital I/O
analog in only reads current
I have a cFP with an AI-110 in it.  In MAX I can only get the cFP to measure current.  How do I configure it to measure voltage?  I don't see any option for it.
(3,392 Views)
Jo-Jo,
Measuring Voltage or Current is determined by which terminal you wire your signal to. See the operations manual, pg 4 for a mapping of Pinouts to signals. Telling MAX the range of the measurement and type is determined by expanding your controller's ip addres under remote systems in MAX, selecting the ai-110 under the controller, then selecting a channel and setting the "range". Post to let us know if that helped.
Chris C
(3,376 Views)
Got it, thanks.  I had made a couple of dumb mistakes.
(3,373 Views)
