Digital I/O
cRIO chassis pinout - which pin is ground?
Got the 5V pin, which is ground? This is a 9073 integrated chassis.
Message Edited by trouinky on 03-27-2009 09:30 AM
Tommy R.
(4,875 Views)
Can I ask why you are accessing the chassis pins directly?  I would definitely not recommend powering any device or sensor using these pins, since there is very little protection on them.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,845 Views)
Found out what we needed to know from this article.
http://zone.ni.com/devzone/cda/tut/p/id/4539
Made our own "module" to invert the RS-232 from the chassis through a Max232 IC to drive an LCD.  Just tapped 5V (with plenty of protection diodes) from the backplane and ran DB-9's from the chassis to the new module and back to the LCD. Viola!
Tommy R.
(4,842 Views)
