Digital I/O
cRIO lost FPGA part
Hi everyone,
This morning I try some exemple from ni.com to download FPGA bitstream in a cRIO.
I follow this tutorials : http://zone.ni.com/devzone/cda/tut/p/id/6465
After that, my FPGA part has disappear from my cRIO. See the cRIO9074-Titus in the enclosure.
Somebody can help me to find again the FPGA part ?
(4,257 Views)
And thank you for posting here.
Did you try to reset your compactRIO? Did you try to restart your computer and Measurement & Automation (MAX)? Did you try to "Create a new object" in order to find your FPGA part back in MAX? Are all the switches of your compactRIO on OFF position? Did you try to format your compactRIO?
Try these solutions in that order and feed me back results.
Regards
Jérémy C.
NI France
(4,247 Views)
Thank you for your time.
Did you try to reset your compactRIO? - Yes nothing change
Did you try to restart your computer and Measurement & Automation (MAX)? - Yes nothing change
Did you try to "Create a new object" in order to find your FPGA part back in MAX? - No but how create a new cRIO object in max ?
Are all the switches of your compactRIO on OFF position? - Yes
Did you try to format your compactRIO? - Yes logicial and Flash memory and nothing change.
Regards MH. Pottier
(4,243 Views)
When you say "logicial and Flash memory", you mean you did a left click on your target and format you compactRIO? (like this)
Did you try to reinstall the software on your compactRIO?
In order to adding a new object, click on the "peripherals and interfaces" of you target and click on "Create a New Object" like this:
... and tell me if create a FPGA part or something similar is available.
When you create a new project and you add your compactRIO, if you choose to discover your peripherals and devices, do you see your compactRIO? Can you choose between using Scan Interface or LabVIEW FPGA Interface? What model of compactRIO do you own?
Jérémy C.
NI France
(4,239 Views)
Bonjour,
On va continuer en français, je pense que ce sera plus facile pour nous deux.
Quand je dis logiciel et mémoire flash, je parle des deux comme sur vos deux premières captures. Dans MAX, je ne peux pas créer de nouvel objet FPGA comme sur la derniere capture. J'ai le choix entre GPIB-VXI, Port (Serial or Parallel) et VISA TCP/IP.
Quand je crée un nouveau projet, il trouve bien mon cRIO, je peux ajouter une carte FPGA au projet, mais quand je compile et que je download le code sur la carte, j'ai l'erreur -63192.
Le cRIO utilisé est un 9074.
Serait-il possible de faire un reset usine pour retrouver la configuration du cRIO d'origine ?
Cordialement
Marc-Henri POTTIER
ARCALE
(4,236 Views)
I'm sorry but you posted on an english forum so you have to write in english.
Could you change the slots of your compactRIO's module(s) and tell me if anything changes?
Try to reinstall your FPGA Module, your drivers and then, format your compactRIO again et reinstall the softwares. Do you put the "Safe Mode" on ON position when you reset, format or reinstall the softwares on your compactRIO?
Please find the documentation of you compactRIO : CompactRIO 9074's Manual
Could you send me a screenshot of the softwares that you have installed on your compactRIO? (like this)
When you launch Start»All Programs»National Instruments»NI-RIO»RIO Device Setup, do you see your RIO0 (FPGA)?
Jérémy C.
NI France
(4,231 Views)
Ok for the English.
I have contact the NI support and my cRIO will be send to the support for reparation.
Thank for your time.
(4,229 Views)
