Digital I/O
cable adapter 183139-02
Does anyone have a pinout diagram for the 68F-50M DIO cable adapter 183139-02? Trying to use a PCI-DIO-32HS card (68 pins connector) to interface with hardware designed to interface with a AT-DIO-32F card (50 pins connector). I believe that cable adapter 183139-02 is the correct part. However, I would like to see a pinout diagram to verify the configuration but could not find anything on the NI website.
(3,627 Views)
I have attached the pinout for you. Have a great day!
(3,627 Views)
