Digital I/O
can i read the voltage and amperage with ni 9203, ni 9205 in solar panel?
(3,098 Views)
Hi khorir,
This depends on what the signal range the solar panel produces, but the 9203 and 9205 will be able to read voltage and current signals.
Look at the datasheet of the solar panel to determine what the typical signal range is.
You may need to amplify and condition the signal to ensure the best reading from the NI devices.
Best
Alex
Hardware Engineer
(3,074 Views)
ok
(3,060 Views)
Please mark the above comment as solution if it answered your question. This way others may easily find the answer if they have the same question.
Alex
Hardware Engineer
(3,052 Views)
