Digital I/O
can the 5V on USB-6210 be connected directly to one of the digital input lines?
Just wondering if the 5V line could be connected directly into one of the digital lines?
I want to know when a switch is closed, so was thinking of 5V from the USB-6210 card to ones side and then into the digital input line. or will it require a load resistor?
(3,313 Views)
Typical practice is to use a pull up resistor to the 5V line, 4700 ohms should do well. See page 87 of the manual below for details:
http://www.ni.com/pdf/manuals/371931f.pdf
-AK2DM
(3,309 Views)
