Digital I/O
change notification syntax in 6527: DIG_Change_Message_Config
I like to add discrete I/O input pins from 2 ports to be monitored (generate events). When I use  DIG_Change_Message_Config function for one port, it works.The
riseChanStr
and fallChanStr string syntax is confusing for more than one port. I used function refence and followed this pattern.., but it doesnot work.
1. (0, 3, 5) port 1, lines 0, 3, and 5
1.0:5,2.1:4 port 1, lines 0 through 5; port 2, lines 1 through 4
It only accepts one port setting. Please give me a description of the syntax for multiport. For instance:
*fallChanStr ="0.7, 1. (0, 3, 5), 2.0:4"   ... htis doesnot work.
(3,821 Views)
Hi delowar,
Are you using the NI-DAQmx driver or the Traditional NI-DAQ (Legacy) driver?
If you are using NI-DAQmx, you can try these as your strings:
For port 1, lines 0, 3, and 5:
"Dev1/port1/line0, Dev1/port1/line3, Dev1/port0/line5"
For port 1, lines 0 through 5; port 2, lines 1 through 4:
"Dev1/port1/line0:5, Dev1/port2/line1:4"
I hope this helps!
Erik J
(3,784 Views)
Thank you Erik. I am using Traditional NI-DAQ (Legacy) driver in CVI environment.
After trying many different possible syntax, I think the port string syntax would be
string ="(0.2,3,6,7), (1.4,6,7)"... translates to    port0 line 2,3, 6,7  and port1 line 4,6,7
It seems to work. Thanks again.
Delowar
(3,779 Views)
I'm glad it works, good luck in your application!
Erik
(3,773 Views)
