Digital I/O
combining a digital I/O module with a flowmeter(sensor) and taking measurements in Labview
So, we can say that I am a newbie in Labview and I am a little bit confused here.
I have different types of digital I/O modules and sensors for checking if the cooling water is running or not(There are already 3 modules programmed, and I will add another one to the dock and pair it with the flowmeter). I succesfully used DAQ assistant but I do not know how to get data for the flow rate etc. I could only tell if the module sensor combination was working or not. is there anyone knows how to do that ? i.e I should be able to tell if the cooling water is not flowing and so on
thanks in advance!
(2,180 Views)
Hello S.p.r.x.77,
Could you please share more info?
What sensor do you have?
What type of DAQ you are using?
What kind of signal you should receive from the sensor?
__________________________________________
The best way to thank, is to give KUDOS
(2,013 Views)
