Digital I/O
compact PSH27-50F-D1 alternate, or connector details PCMCIA side
I am aquiring a DAQcard-DIO-24 for use with a compact device that cannot fit the large 50-pin user end connector that the PSH27-50F-D1 cable is equipped with. I would like to know a) if there's a cable available that have a smaller user end footprint, or b) details on the connector type used on the PCMCIA side of the cable, that is if this is a standard connector likely to be available from other manufacturers.
A cable carrying the PSH27-50F-D1's PCMCIA side connector in both ends, accompanied by a SMD mating socket for the target board would be an ideal solution. The smaller the better.
Kjetil
Message 1 of 1
(3,576 Views)
