Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
configuring DIO-96 ports
Jarek
Member
08-17-2005
04:16 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When I use Port Config VI all lines are pulled low. My equipment is working with reverse logic and pulling all lines low makes all valves open and all pumps running which is not to good. Is it possible to make port config without setting lines low ?
0
Kudos
Message
1
of 1
(3,437 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
