Digital I/O
continous output pattern with DAQmx not finishing output
Hello Johannes,
i have now my system running on 3 computers without a fault.
to remind, i have a 6533 card, which i program to output at 2MHz using the burst timing.
it is still not working at 2 MHz in the normal timed solution, but since it works in this burst mode i dont really care.
the problem suddenly occurs in the 4th computer i install this program in: burst mode doesnt work! it sends out one word, and then stalls!
using the other time mode lead to the same behavior as encountered on the other computers, but i cant really use it, since it wont run at the desired frequency.
the main difference there is that we installed NI-DAQmx 8.5, instead of the one shipped in the labview CD (drivers from august 2006), version 8.2
we tried installing DAQmx 8.3 instead, but the problem is still there.
Do you have an idea for me?
Thanks!
... And here's where I keep assorted lengths of wires...
Message 11 of 11
(859 Views)
