Digital I/O
continuously acquir data
I own a DIO-32HS board, program in C++, and I would like to acquir continuousely digital data. I use DIG_Block_in function, but I must write a parameter (count) to determine the number of sample I would read... and in my case I would read until I said Stop via a push button for example.
May be this function (DIG_Block_in) is not appropriate? but I don't know which other function to use.
To resume the simple things I would do is acquir 8 bits on port 0 on each clock edge (clock is generated by DIO-32HS board). and start/stop via a key or a push button.
the speed of my data input is around 1MHz.
somebody could help me?
thanks, Fabien.
(3,249 Views)
I attached an example which do a digital continously acquisition.
I hope this help you.
Regards
VéroniqueD
NI France
(3,210 Views)
