Digital I/O
controlling a sub vi array with a main vi
I'm trying to figure out how to write an boolean array cluster from a main program to control lines in a subvi control array. Please see attached. thanks
(3,482 Views)
Scott,
I worked with your code to get it how you need it. I also put comments in to describe what I did.
-Sal
(3,482 Views)
Hi Salvidor, I think I fixed it by simply dragging the main boolean array to the while loop in the sub vi. I was hoping to keep them seperated for keeping modular, however, I can work with this. If you do see a solution feel free to send it my way. Thanks for your help!
Scott
(3,482 Views)
