Digital I/O
crio 9024
Alexander,
ive bwwn through all steps, run it as start up, there is no error msg, but does not run
Message 11 of 12
(2,699 Views)
Hello AutonomousMode,
have you deleted the elapsed time vi and replaced them stop with a false constant?
  1. Make a indicator for the iteration of the loops.
  2. Go in the specification under advanced you find a checkbox enable debuging, set this please.
  3. Build and deploy the startup.
  4. In LabVIEW under operate is a option to debug the a exectuable, please select your Rio and look, if the code is running, or what happend.
Does a simple vi without the kukabot vi´s run?
For what platform are the vi´s designed, that the kuka bot controls, is there a DLL inside or not?
You said you can control the bot, if the vi´s run on the host, how does the communication works inside of the vi´s?
best regards
Alexander
Message 12 of 12
(2,698 Views)
