Digital I/O
crio with 9403 module for pwm output in FPGA
Hi, everyone.
I am trying to generate PWM signal by using crio + 9403 in FPGA.
However, the program does not go well.
For example, I can only generate 40 Khz PWM.
As another example, the motor does not works well in the case of duration above 15%.
Is there anyone who have tried this hardware configuration for generating PWM output?
How should I do?
Message 1 of 1
(4,886 Views)
