Digital I/O
daq6025e digital output
I want to use DAQ6025e board to output buffered digital signal to port 2( PA0...PA3). However, I failed to run some examples from the e-serials.llb. for example, to Dig Multi-line Direction (E).vi, the "direction map" pin only can be set to "-1". As to "Continuous CDO with AO (E).vi",
I even cannot pass the configuration block using channel 2, it causes error,"10403".
I wonder to know whether the DAQ6025e can support buffered digital output  (because all examples that send immediate signal to port/line are working). If possible, could you please provide a sample code? thanks
(3,093 Views)
I noticed that you posted a similar issue in another forum.  I am going to post my reply on the other discussion forum  and we continue the thread over there.
Hal L.
(3,074 Views)
