Digital I/O
data transition time on PCI-6541
The specification "data transition time" is provided for some digital waveform generator/analyzers; however, I didn't see this information for the PCI-6541.  Can I assume that transition time will have maximum around 1ns?  Or is this way off?
Thanks!
mlloyd Smiley Happy
(3,545 Views)
Hi Mlloyd, With respect to the term "data transition time" and the 6541, what information are you looking for? Are you looking for output minimum / maximum rise and fall times? Are you looking specs on the required rise / fall times on the inputs? It is not fair to assume that the data transition time is the same as it would be on a scope card. Best Regards, Evan R. Applications Engineer National Instruments http://www.ni.com/support
(3,534 Views)
Output minimum/maximum rise/fall times was what I was looking for.  This information is not critical; rather, since it was specified for other cards I thought it might be available and I had just overlooked it.
If you know these specifications for the PCI-6541, I would be interested in their values.  Otherwise, I think I'll survive...  Smiley Happy
Thanks for your help,
mlloyd
(3,526 Views)
