Digital I/O
delete script in HSDIO?
Does anyone know if it is possible to delete named scripts from an HSDIO card using LabVIEW 8.2/HSDIO1.5?
In a single generation session, I would like to write waveforms and a script to an HSDIO card, generate according to the script, and then delete these waveforms and the script in order to repeat this entire process several times.  I am using "niHSDIO Delete Named Waveform" to delete the waveforms, but I can't figure out a way to delete the script, too.  This is a problem, because I eventually run out of memory on the HSDIO card since the new waveforms and script are written after the last old script.
Any help is appreciated!
Angie
(3,325 Views)
Hi Angie,
There is currently no way to delete a script in NI-HSDIO.  However you can overwrite a script by calling "niHSDIO Write Script" with the same script name.  That way you may be able to conserve some space by overwritting "older" scripts.
Onome
(3,304 Views)
