12-19-2007 08:18 AM
12-20-2007
01:54 PM
- last edited on
09-26-2025
09:11 PM
by
Content Cleaner
Hi Samiali,
Welcome to the forums! Your application sounds interesting. Can I ask what Data Acquisition (DAQ) card you are using to retrieve the data from your sensors?
There is a lot of good documentation on line that you can look through to get a feel for programming in LabVIEW. I would suggest Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications. The DAQ Assistant is good beginner level function that will allow to acquire your sensor data without much difficulty.
Also, there are a number of great example programs included with LabVIEW that have explanations and can give you an idea of program flow and functionality. You can just use one of these programs or modify one to suit the needs of your application. The example can be found in LabVIEW by navigating to the Help Menu>> Find Examples>> expanding the Hardware Input and Output folder>>and then looking in the Analog Measurement files. I would suggest looking through some of the examples in the Voltage and Acceleration folders.
Lastly, there are a number of customer education courses that take place all over the country. If you are interested, I could have someone contact you with more information.
I hope this information helps. Good Luck, Mallori M.
