Digital I/O
different voltage levels at the PCI-6552 outputs
Is it possible to have different voltage levels simultanously at the output of PCI-6552. e.g. 2 V and 3.3 V.
(3,425 Views)
Hello gues1,
The NI 6552 allows you to individually program your output low voltage and output high voltage. Technically, you are able to set the low voltage to 2 V and the high voltage to 3.3 V. Then, one channel may output a logical low (2 V), and another may simultaneously output a logical high (3.3 V).
If, however, you would like to simultaneoulsy generate 0 V -> 3.3V logic on one channel and 0 V --> 2V logic on another channel, that would require 3 different voltage settings (0, 2, 3.3), which is not possible.
Does that answer your question?
(3,425 Views)
