09-21-2005 06:57 PM
okay I successfully start triggered from a 32-bit pattern on port0:3.
If it sees that same pattern again, will it start trigger again and start over? Is there a way to stop trigger on a pattern?
09-21-2005 07:00 PM
09-22-2005 11:10 AM
09-11-2006 02:28 PM
09-12-2006 04:03 PM
Hello Ryan,
I am happy to hear that your application has been working well.
As for your new application, you should continue to use CfgDigPatternStartTrig() because you cannot use the same pin for triggering and acquiring data when using CfgDigEdgeStartTrig. With the pattern start trigger, you can use the same pin when acquiring from only one line.
I think that this is the answer to your question, so if not, or if you have additional questions, please let us know!
Laura
09-12-2006 06:04 PM
09-13-2006 01:06 PM
