Digital I/O
digital waveform output with daqpad 6020e
Can the daqpad 6020e do continuous digital waveform output on any of the digital lines? If so, what lines. If not, what devices in the same price range can?
(3,403 Views)
Paul, what kind of waveforms, speeds, and repeatability are you looking for? If you can handle software timing and jitter, then you could just change the digital outputs in a loop.
If you need fast, steady, repeatable pattern generation, then we offer the NI-6533 and NI-6534. The DAQPads don't currently have any support for digital pattern generation. You can get it in PCMCI format however with the NI-6533.
Hope this helps,
John Nieri
(3,403 Views)
