Digital I/O
dio-96 startup state
Hi all, I'm using a DIO-96 card, I've noticed that as soon as the pc is powered up it's logic gates go HIGH and give me +5v output.
I'll be using this card to drive relays so I'd like for the card logic to start LOW. Is there anyway I can do this?
I've looked through the forums and I cant find an example of how to do it with my card, only a DIO-96pnp.
My card is pictured here ->
Thank you
Message Edited by BassTeQ_ on 02-13-2007 06:38 PM
(3,631 Views)
AFAIK the PCI-DIO96 comes up in input mode and has pullups on its inputs.  It also doesn't have a programable startup setting. You will have to switch to the newer PCI-6509 to get that feature.
(3,617 Views)
Thanks for your reply, although that wasn't the answer I wanted to hear 😛
Cheers
(3,604 Views)
