Digital I/O
does pci 6602 support hardware-timed DIO
does the PCI 6602 support hardware-timed DIO?
thanks!
(1,931 Views)
No it does not.  It's replacement, the PCIe-6612, does.
What are your DAQ requirements, what DAQ hardware do you already have, and can you purchase anything new if you need it to meet your requirements?
-Kevin P
(1,891 Views)
Hi Kevin,
thanks for the help, I'd like to synchronise three digital output channels (one to external trigger a camera, two for laser control). Do you know if this is still possible?
thanks,
anna
(1,884 Views)
It will depend on how regular the timing relationships are among all the signals.  If entirely regular, there's a good chance it's possible.
You'd end up using counter tasks to deliver hardware-timed digital pulses.  They'll still be TTL-logic compatible digital signals, but they'll come from the counter subsystem of the board instead of the "regular" DIO subsystem.
Some keywords that can help you
- "Arm Start Trigger"
- "initial delay"
- "retriggerable single pulse"
I might be able to help more if you can describe the needed timing relationships in detail, including both any input signals to react to and output signals to generate.
-Kevin P
(1,879 Views)
Thanks! The timing is entirely regular.
I have two lasers and a camera (andor ixon 897) connected to the PCI 6602. I'd like to have it so that the lasers alternate (e.g. every 10ms) and each time they alternate, the camera starts a new frame (so exposure 10ms). i.e. the start of the frame is synchronised with the laser alternation. I originally thought this could be done by using the camera internal triggering to trigger the lasers but since PCI 6602 does not accept hardware time DIO, I guess I have to go the other way round and use the camera on external triggering?
In this case, the lasers would require digital ouputs that are triggered by the rising/falling edge of a counter? and the camera would need some sort of waveform?
(1,874 Views)
If I understand your system correctly, I see it like this:
You'd have 3 pulse train tasks with their timing sync'ed by a combo of an "Arm Start Trigger" and careful coordination of their timing parameters (high time, low time, initial delay).  Each would drive one of your 3 devices.
If you want to configure them as *finite* pulse trains, be aware that each task will consume 2 of your board's 8 total counters - both the one you configure explicitly and the one it's "paired" with.  Pairs are { (0,1), (2,3), (4,5), (6,7) }.  So this takes 6 counters total.
Or you can configure as continuous and decide in software when to stop them.  This takes 3 counters total.
-Kevin P
(1,862 Views)
