Digital I/O
dynamic dynamic digital output
I want to increase the speed of a stepping motor to become higher speed and after that I would change the speed of the working motor.
So I need a dynamic digital signal.
How could I make this or could I control the counter on my connector block?
Thank you for helping me.
Smoofo
Message 1 of 10
(4,530 Views)
Hi Smoofo,
If you want help on this, more information is needed like which hardware you are using and how it is connected to the
stepping motor.
Message 2 of 10
(4,501 Views)
Hi emvee,
I have a controler for my steppimg motor who only need digital signals. As faster it becomes the puls as faster it will run.
How could I make this or could I control the counter on my connector block to increase the pulses and control them during the running.
Thank you
Smoofo
Message 3 of 10
(4,486 Views)
Hi Smoofo,
I can still not answer your question as I do not know what hardware you are using. Please give the type number of the card you are using and how it is connected to the stepping motor.
Message 4 of 10
(4,484 Views)
Ok sorry I forgot this.
I have a PCMCIA-Card "DAQCard-6036E" which is conected to a "SCB-68" 68-Pin Shielded Connector Block.
Thank you very much for your help.
Message 5 of 10
(4,483 Views)
I am not familiar to this card, and do not know the details of the stepping motor control. But if I assume that you just have to generate pulses with a variable frequency (0-100 Hz?) you can use two methods I think:
  1. Change the generation clock from 0-100 Hz
  2. Keep the generation clock fixed at a high clock rate (5 KHz) and modulate the data to make the 0-100 Hz pulses
Maybe even use the counters of the DAQCard-6036E card...
Message 6 of 10
(4,479 Views)
Thank you for answering so fast.
The prolem that I have is: With every puls the motor is doing one stepp. So if I have a frequenz of 200Hz the Motor is doing 200 Stepps per secund.
This works till 700Hz after that the frequez for starting is to high so I need at first a slow frequenz of the puls and than increas them to the maxim of 4000Hz.
So the problem is that I don't know how I can  control the pulses or generate them that I can control and varied the speed of the motor during it works.
Do you know solution of my problem?
Thank you again
Message 7 of 10
(4,477 Views)
Hi Smoofo,
Why don't you just increase the frequency using the normal function to set the sampling frequency? Maybe you will have a (very) short hick-up but with a modern computer that should be that short that it will not have any effect.
NB: What programming environment are you using? Can you post the code you are currently using?
Message 8 of 10
(4,472 Views)
one more question to this problem.
What do you mean with normal function for sampling a frequency.The normal signal simulation has problems increasing to 4kHz.
I know it sounds easy but it still would not work.
I only won't to Increase the freaquency from a digital output signal from 0-4kHz!
Thank you
Message 9 of 10
(4,457 Views)
Sorry for my english I mean
I only WANT to Increase the freaquency from a digital output signal from 0-4kHz!
Message 10 of 10
(4,453 Views)
