Digital I/O
encoder robotics
so, the encoders are normal quadrature encoders, without a Z-index. I bought the 6602 board, and can read encoder signals now. But why did you mentioned that the capability is just 4 encoders. One timer per encoder is enough, isn't it. I just need to connect pos. A to source of counter, pos. B to digital input, +5V and ground, or?. So, but I got a problem with writing these datas to file in Excel. Can you help me with that? I just want to get columns...
Thanks in advance.
Message 11 of 12
(1,160 Views)
Hello, ok, command back. I can write to file. Next problem: I am reading not the right values, means:(pci6602)  Phase A is connected to source of counter 0(pin2), Phase B connected to counter 0 aux(pin40), +5V(pin1)  connected and ground to D GRD(pin36).
So, my vi is attached. my values are round about 0.33 what i expect to see. Why, even when I use an example, I cannot get the right results...
Thanks in advance.
Message 12 of 12
(1,151 Views)
