Digital I/O
error -10401 (unknown device) when driving daqpad 6508 after power down
I'm currently using a DAQPAD 6508 to do some IO. This is working OK exept for one thing:
When the PC which is using the DAQPAD is rebooted, a "-10401" error occurs (unknown device) !!! This error occurs in the DIO Port
This persist until I open Measurement explorer and open the Test Panel and do some random settings. When I then run the application again, everything works...
Remark that the DAQPAD 6508 is driven though USB.
Attached you'll find the vi that I use to drive this device...
thanks in advance for the help...
(3,217 Views)
I was just describing that this error occurs in the DIO Port Config.vi before my explorer did some strange things and submitted my post...
Here is the vi I'm using
thanks
regards,
Marino
(3,214 Views)
